The Seat Cordoba WRC specs(Evo 2, tarmac)
  • Konbuyu başlatan Konbuyu başlatan kurtbil
kurtbil
25 Ağu 2009
Engine
Cast aluminum block and head construction, front transversally mounted.
1995 cm3 , water cooled turbo charged. Bore: 83mm, stroke: 92.1mm. 2 OHC belt driven and solid tappets. 4 valves per cylinder positioned in V at 25°. Oil radiator. Compression ratio: 8.1:1
Engine output: 315Bhp @ 5300rpm. Engine torque: 520Nm @ 3500rpm. Garrett/Allied Signal TR 30R turbo charger Magneti-Marelli Step 9 engine management (the previous version was using a Marelli MR3 ECU)
Transmission
Full time four wheel drive. Prodrive active/hydro-electronically controlled front, center and rear differentials. 50%-50% F-R torque distribution. Six speed Hewland/Prodrive/Seat reworked non synchronized, sequential shift gear box transversally mounted. Carbon triple plate clutch hydraulically actuated.
High ratio rack and pinion, power assisted steering.
Suspension
Front: Independent McPherson struts lower wishbone, coil springs and Öhlins gas shock absorbers, cabin adjustable antiroll bar.
Rear: Independent McPherson struts lower wishbone, coil springs and Öhlins gas shock absorbers, cabin adjustable antiroll bar.
Brakes
Front: 380mm vented disks fixed 6 pot water cooled aluminum calipers.
Rear: 304mm vented disks fixed 4 pot aluminum calipers.
Chassis
Monocoque, steel construction.
Wheels/Tires
8"x18" wheels, Pirelli 225x650/18
Dimensions
Length: 4172mm
Width: 1770mm
Height: 1500mm
Wheelbase: 2443mm
Front track: 1520mm
Rear track: 1520mm
Laden weight: 1230Kg (FIA homologation minimum)
Heralde konuyu dogru yere acmısımdır
Yavrum benim. İntercoolerın üstünde SEAT bile yazıyor 😀
bu tarz jantlar çok hoşuma gidiyor.özellikle ömercanınkiler şahane.
bu arada paylaşım içinde teşekkürler Can.sayenizde teknik konularıda öğreniyorum artık
Hayrını gorun aybars bunlar canavar modellerden bılmemız lazım seatcılar olarak 🙂
315 hp. i görünce çok şok olmadım ama 520 tork baya iyiymiş
Can kardeşim,böyle bir motor üretimi varmıydı seatın veya vw grubun 99 veya 2000 yıllarında.Hiç rastlamadım.Sanırım özel yapım bir motor.Teşekkürler.
Tamamen WRC ıcın uretılmıs bır motor tekın abi zaten,cadde kullanımı ıcın uretılmedı ama aynı arabanın cadde ıcın yapılmıs 1.8 t 150 hp lık versıyonu da bulunmakta.Malum satılıklar sıtesınde b tane gormustum ama genel olarak gırısı yapılmadı heralde
39,207Konu
764,022Mesajlar
22,105Kullanıcılar
DeliziasSon üye
