Why is my brake pedal soft after changing brakes?
Whiteman
18 Şub 2023
Air in the brake line(s) is the most common cause of a soft/spongy brake pedal . If air gets into the brake lines, it can prevent brake fluid from flowing properly, causing the brake pedal to feel spongy or soft. If the brakes are soft or spongy, this is a good time to change or flush the brake fluid.
