vag-com ile aldıgım arızalar hakkında yardım
  • Konbuyu başlatan Konbuyu başlatan SaLvia
SaLvia
9 Ağu 2011
VCDS-Lite Version: Release 1.1
Monday, 18 June 2012, 20:23:51.
Chassis Type: 6L - Seat Ibiza/Cordoba
Scan: 01,02,03,08,09,15,17,19,25,37,44,46,55,56
Address 01: Engine Labels: 036-906-034-APE.LBL
Controller: 036 906 034 AH
Component: MARELLI 4MV 4461
Coding: 00061
Shop #: WSC 00000
VCID: 58C30B63AB1D
VSSZZZ6LZ2R052351 SEZ7Z0B1655184
2 Faults Found:
16786 - EGR System: Excessive Flow
P0402 - 35-00 - -
16502 - Shareware Version. To Decode all DTCs
P0118 - 35-10 - Please Register/Activate - Intermittent
Readiness: 0000 0000
Address 08: Auto HVAC Labels: 6Q0-820-045.LBL
Controller: 6L0 820 045
Component: Klimaanlage X0840
VCID: E5BDB2976C6F
6 Faults Found:
01271 - Positioning Motor for Temperature Flap (V68)
30-10 - Open or Short to Plus - Intermittent
01596 - Shareware Version. To Decode all DTCs
30-10 - Please Register/Activate - Intermittent
01271 - Shareware Version. To Decode all DTCs
41-10 - Please Register/Activate - Intermittent
01596 - Motor for Outside/Recirculated Air Flap (V154)
41-10 - Blocked or No Voltage - Intermittent
29-10 - Please Register/Activate - Intermittent
28-10 - Please Register/Activate - Intermittent
türkçeleri yokmu bunun birde bu arızalar sürekli değil ise arızaları sil tekrar gelirse aratır bence
google a vw foult codes yazıp numarasını yazarsan doğrudan ne olduğu çıkıyor.
16786/P0402/001026 - Exhaust Gas Recirculation (EGR): Excessive Flow
Possible Symptoms
Malfunction Indicator Light (MIL) ON
Reduced Exhaust Gas Recirculation (EGR)
Reduced Power Output/Engine running rough
Increased Emissions
Possible Causes
Exhaust Gas Recirculation (EGR) Valve stuck open/leaking/faulty
Exhaust Gas Recirculation (EGR) System leaking/faulty
Wiring and/or Connector(s) from/to Exhaust Gas Recirculation (EGR) Valve faulty
Possible Solutions
Check/Clean Exhaust Gas Recirculation (EGR) System
Check/Replace Exhaust Gas Recirculation (EGR) Valve
Check Wiring and/or Connector(s) from/to Exhaust Gas Recirculation (EGR) Valve
bu egr valfi hatasını daha oncede vermişti acaba bu hatayı çözen veyahut egr iptali yaptıran varmı
16502/P0118/000280 - Engine Coolant Temperature Sensor (G62): Signal too High
Possible Symptoms
Difficulties with starting a cold engine.
Starting the engine when engine is warmish or warm, idle rpm immediately is 1200 - 3000 rpm.
RPM at idle is irregular.
With all engine temperatures idle rpm will often vary between 900 - 1000 rpm.
With engine warm (90 °C) the engine temperature suddenly drops (70 °C) and slowly comes back to 90 °C.
Bad acceleration during warm-up.
Diesel Engines: Glow plug indicator may be on for a longer than normal time or at ambient temperatures where it shouldn't come on at all.
Possible Causes
The electrical signal coming from G62 is too low
Wiring and/or connections faulty (short circuit?)
Engine Coolant Temperature Sensor (G62) faulty
Possible Solutions
Check wiring and connections
Check / Replace Engine Coolant Temperature Sensor (G62)
Special Notes
In many cars between MY 1995-2002 the G2/G62 had a bad reputation for failing often. The original G2/G62 sensor is black and the improved replacements are green.
bu hatayı da hararet müşiri olarak gördüm ama
aracı calıstırdıgım zamanlarda rölantide
devir saati 1100 1200 civarlarında çalışıyordu
şimdi havalar sıcak oldugu için 800 devirlerde çalışıyor sanırsam
hararet göstergesinde de bi gariplik sezmedim
01271 - Positioning Motor for Temperature Flap (V68): Faulty
Possible Causes
Wiring/Connectors from/to Positioning Motor for Temperature Flap (V68) faulty
Positioning Motor for Temperature Flap (V68) blocked
Possible Solutions
Check Positioning Motor for Temperature Flap (V68)
See Measuring Value Blocks (MVB)
Perform Output Test
Perform Basic Setting
Check/Repair Wiring and Connectors
ben bu hatadan hiç birşey anlamadım 🙁
39,134Konu
763,865Mesajlar
21,904Kullanıcılar
dekaridezSon üye
