Focus ST vs Astra VXR..
YCO
26 Ağu 2009
Focus ST
Country of origin United States
Numbers built N/A
Produced from 2005 - 2007
Introduced at 2005 Geneva Motor Show
Engine
Configuration Duratec ST Straight 5
Location Front, transversely mounted
Construction aluminium alloy block and head
Displacement 2.522 liter / 153.9 cu in
Bore / Stroke 83.0 mm (3.3 in) / 93.2 mm (3.7 in)
Compression 9.0:1
Valvetrain 4 valves / cylinder, DOHC
Fuel feed Fuel Injection
Aspiration KKK Turbo
Drivetrain
Chassis/body unitary steel
Front suspension McPherson struts, coil springs, anti-roll bar
Rear suspension Multi link, coil springs, anti-roll bar
Steering rack-and-pinion, power assisted
Brakes ventilated discs front, solids rear, ABS
Gearbox 6 speed Manual
Drive Front wheel drive
Dimensions
Weight 1317 kilo / 2903.5 lbs
Length / Width / Height 4362 mm (171.7 in) / 1840 mm (72.4 in) / 1497 mm (58.9 in)
Wheelbase / Track (fr/r) 2640 mm (103.9 in) / 1535 mm (60.4 in) / 1531 mm (60.3 in)
Performance figures
Power 225 bhp / 168 KW @ 6100 rpm
Torque 320 Nm / 236 ft lbs @ 1600 rpm
BHP/Liter 89 bhp / liter
Power to weight 0.17 bhp / kg
Top Speed 241 km/h / 150 mph
0-60 mph 6.5 s
Opel Astra VXR
submitted by Richard Owen
engine ECOTEC Inline-4
position Turbocharged
valvetrain 4 Valves per Cyl
displacement 1998 cc / 121.9 in³
bore 86 mm / 3.39 in
stroke 86 mm / 3.39 in
compression 8.8:1
power 170 kw / 237 bhp @ 5600 rpm
specific output 120.12 bhp per litre
bhp/weight 172.29 bhp per tonne
torque 320 nm / 236.0 ft lbs @ 2400 rpm
driven wheels FWD w/ESP
wheel type Fve Spoke Alloy
front tires 225/40 R 18
rear tires 225/40 R 18
f brake size x 321 mm / x 12.6 in
r brake size x 278 mm / x 10.9 in
front wheels F 45.7 x 20.3 cm / 18 x 8 in
rear wheels R 45.7 x 20.3 cm / 18 x 8 in
weight 1393 kg / 3071 lbs
length 4290 mm / 168.9 in
width 1092 mm / 43.0 in
height 1420 mm / 55.9 in
gear ratios :1
top speed 244.6 kph / 152 mph
0 - 60 mph 6.2 seconds ..
testlerini oldum olası yetersiz görüp nefret etsem de Fifth Gear'dan..
http://www.youtube.com/watch?v=zSfvL3oajF0
VXR, ST nin yanına bile yanaşamaz. Bu arada ST'nin country of origin UK olması lazım ABD değil..
motor olarak pek bi bilgim yok ama bi dergide bakmısıtm st ye torpidoda biyerde motor sesini yankılı bi şekilde içeri veren cihaz varmıs çok etkilenmiştim genel olarak arabadan lansman rengi turuncuda cok güzel.
39,222Konu
764,051Mesajlar
22,143Kullanıcılar
scanmeteSon üye
