YCO
- 26 Ağu 2009
- Yaş
- 37
CLK63 AMG Black Series
engine V8
position Front Longitudinal
aspiration Naturally Aspirated
valvetrain DOHC, 4 Valves per Cylinder
fuel feed Fuel Injection
displacement 6208 cc / 378.8 in³
bore 102.2 mm / 4.02 in
stroke 94.6 mm / 3.72 in
compression 11.3:1
power 378.1 kw / 507 bhp @ 6800 rpm
specific output 81.67 bhp per litre
bhp/weight 293.4 bhp per tonne
torque 630 nm / 464.7 ft lbs @ 5250 rpm
redline 7200
body / frame Unit Steel w/Aluminum Panels
driven wheels RWD
wheel type Forged Alloy
2009 BMW M6 Base Coupe Performance & Efficiency Standard Features
- 4,999 cc 5.0 liters V 10 front engine with 92.0 mm bore, 75.2 mm stroke, 12.0 compression ratio, double overhead cam, variable valve timing/camshaft and four valves per cylinder
- Premium unleaded fuel 91
- Multi-point injection fuel system
- 18.5 gallon main premium unleaded fuel tank 15.4
- Power: 373 kW , 500 HP SAE @ 7,750 rpm; 383 ft lb , 520 Nm @ 6,100 rpm
