    Hello Welcome to Guest!
Orta konsol karbon uygulama ve led montaji
veletifo
Forumdan Uzaklaştırıldı
11 Kas 2012
Beğeniler
36
#1
ARKADASLAR YURT DISINDAN BIR ARKADASINIZ OLARAK ESIMIN ARACINDA YAPTIGIM KARBON FILM UYGULAMASI VE LED UYGULAMASINI MUMKUN OLDUGU KADAR ANLATICAGIM
ORTA KONSOL BIRAZ BOS GÖZÜKÜYORDU VE KLIMA POTANSLARININ OLDUGU YERLERDE SADECE FOSFORLU FILM VARDI.BUDA BIZIM HOSUMUZA GITMIYORDU.ISIK OLUCAKTA POTANSLARI VE HANGI KISIMI ISITMAMIZ GEREKTIGINI GÖRÜCEZ.BU IS BÖYLE OLMAZ DEYIP KOLLARI HAFTA SONU SIVADIM
MALZEMELER:
152*50 CM : 6EURO
LED : 3 ADET 1 EURO
HAVYA
LEHIM TELI
FÖN MAKINESI
ÖLCÜ ALETI
GEREKLI ALETLER
ÖNCELIKLE ORTA PANELI KOMPLE SÖKÜP EVE GETIRDIM o resimler suan elimde yok malesef
DAHA SONRA DEKOR AMACLI KULLANILAN 3 LEDLI AYDINLATMANIN ICINDEN BEYAZ LEDLERI SÖKÜYORUZ UCUZ OLDUGU ICIN BU YOLU SECTIM
ARKADASLAR BILMEYENLER ICIN ACIKLAMAK ISTIYORUM LED E BAKTIGINIZDA KALIN VEDE INCE UC GÖRÜCEKSINIZ KALIN OLAN KISIM EKSIDIR (-) INCE OLAN KISIM ISE (+)DIR.
EGERKI SMD LED KULANICAK ISENIZ YANI UFAK MANTAR KAFA OLMAYAN LED KULLANICAK ISENIZ AYNI SEY BUNUN ICINDE GECERLIDIR.GÖZLERI IYI OLANLAR CIPLAK GÖZ ILE IYI GÖREMEYENLER ISE BIR BÜYÜTEC YARDIMI OLE BAKARSA KALIN VEDE INCE KISMI SMD LED DE GÖRECEKTIR.
ARKADASLAR LED LERI MATKAP YARDIMI ILE DELIK ACTIGIMIZ PANELE YERLESTIRIYORUZ LED BÜYÜK MANTAR KAFA LEDLER ISE 3mm ILE DELMENIZ GEREKMEKTEDIR EGER UYMAZ ISE BIRAZ EGELEMENIZ GEREKIYOR.DAHA IYI OTURMASI ICIN BEN ARKALARINA SICAK SILIKONLA DESTEK YAPTIM
BEN KONTAK ACILDIGINDA LED LERIN YANMASINI ISTEDIGIM ICIN 12+ VE 12- VOLTU DIREK PANELE GELEN KABLOLARDAN ALDIM.MAVI KABLO ILE SIYAH KABLOYU ÖLCTÜGÜMDE 0 VOLT GÖSTERIYORDU KONTAGI CEVIRDIGIMDE MAVI +12 SIYAH -12 OLDUGUNU GÖRDÜM VE DIREK MONTAJ YAPMAYA BASLADIM:KABLOYU DIREK ACMAK YERINE MAKET BICAGI YARDIMI ILE SIYIRIP DIREK USTUNE BAGLANTI YAPTIM BÖYLELIKLE LED LERE ENERJI SAGLANMIS OLDU.
NIHAYET ISIMIZ BITTI.YAPTIGIMIZ DEGISIKLIKLERIN MUTLULUGUNU YASIYORUZ.BIR DENEYELIM DEDIK VEDE MUKKEMMEL BIR SONUC ORTAYA CIKTI.
HER ASAMADA FOTOGRAM CEKEMEDIGIM ICIN ÖZÜR DILERIM.KARBON FILM UYGULANIRKEN BIR YERDEN ISITIP BIR YERDEN GERDIRIR IKEN FOTOGRAF CEKEMEDIM.ARKADASLAR CARBON FILM UYGULAYACAK ARKADASLARA BIR HATIRLATMAM OLACAK ISITIP GERDIRIYORUZ ISITTIKTAN SONRA FILM SETLESIYOR HABERINIZ OLSUN TABIKI TEKRAR ISI UYGULADIGINIZDA ESKI FORMUNU ALIYOR AMA DIKKATLICE YAPINKI ISI UYGULADIGINIZDA YAPTIGINIZ YERLERDE BOZULUYOR.BENIM ILK DENEMEM OLDUGU ICIN BIRAZ KOTU GORUNUYOR OLABILIR AMA EN KISA ZAMANDA TEKRAR SÖKÜP YENI PARLAK FILM UYGULAMASI YAPACAGIM
IYI UYGULAMALAR
seat_leon
22 Eyl 2011
Beğeniler
262
#3
elinize sağlık :) emek isteyen iş, biraz zaman ve elektronik bilgi ister diye düşünüyorum..
tugra kazım
20 Kas 2011
Beğeniler
2,206
#4
MALZEMELER:
152*50 CM : 6EURO
LED : 3 ADET 1 EURO
HAVYA
LEHIM TELI
FÖN MAKINESI
ÖLCÜ ALETI
GEREKLI ALETLER
IYI UYGULAMALAR
öncelikle kendnizi üyelerimizden tanıtırmısınız lütfen ayrıca aynı konudan 2 adet acılmış 1 ri kilit
